Borked card?
22 Oct 2008
Lisburn
I'm getting these weird lines all over the screen when playing FM2014 and other games.
I've rolled back the factory OC to 1Ghz (was 1150) and dropped volts down too but no change. Is the card on its way out? It's a MSI 270x. Has anyone else had issues with this brand of card?
No it isn't go into FM 2014 settings and change it to software rendering, I had this with my R9 290 and thought it was dead but it was only FM 2014 that did it, happened since 14.5 AMD Beta drivers, not sure if 14.7 fixes it. Could be broken if it is in other games but FM 2014 was fixed by software rendering.
Try what senor Doogles suggested and don't forget the links in my sig. Include the screenshot too.
Will try when I get home cheers folks. Had similar lines in Grid 2 but just the once...right after playing FM2014? Odd. Will report back....
What bit in the menu do I go into? Trying to find it and I can't :o
