- 16 Nov 2002
The only time I saw that code was when I put too much load on psu. Or rather pushed the clocks too high on CPU and gpu's weren't getting enough power.
That was with a clocked 3960x and 3 x clocked 290. Backing off the clocks stopped it.
You have mentioned 550w and 750w psu, but not makes. And what's the rest of that setup including clocks, etc?
I have powercool x-viper 750w and antec 550, plus generic no names of greater than 500w to try. The box has:
Motherboard P5n-D, Q6600 (stock), 2x2gb ram, DVD drive (never used as far as I know), a Samsung 840 SSD, video card (was HD6870, now trying these R9 290). 2 x 12cm fans, cpu fan, couple of m/board small heatsink fans.
That's it.
Will try every PSU I can get hold of, but the antec and powercool are both Bronze rated - surely they are enough (550 or 750) to run one of these things playing Youtube videos? And the issue where Youtube runs fine (no errors, no BSOD) without AMD drivers installed surely points to bad drivers? His old card (6870) give an occasional black screen for a second or so every now and again but otherwise Youtube and Minecraft for days (months!) without end.
Same result (BSOD) at least in Chrome. Could try Firefox and see what happens there.
