- 24 Mar 2014
- Inverness,
Brilliant show
indeed !! wish there was a Se 4
Brilliant show
it's not pendantic it's fundamental
If like you are on the ISS, does time exist?
There is no day, no evening, do they even use earth time and seasons?
I don't agree with the big bang or expansion of space theory. There was no big bang..
However everything in space is moving through space, our solar system and our galaxy are all travelling and rotating through space. Rather than the big bang i think it is more sporadic and random and organic in its growth. With galaxies and stars forming at random and at different times and locations. That is much more realistic than just a big bang and then everything exists in its current form, instead, planets, solar systems, stars and galaxies and so on are all growing. Everything in the universe peaks, it has a point where it starts and it has a point where it ends, in between those points there is a peak.
Time is not a man made concept, only the division or allocation of time units is the man made aspect of time. Time itself is linear and exists throughout the universe.
[TFU] Thegoon84;26788069 said:Time is all relevant !
It's just a difficult dimension to traverse
Yes, so what is the measurement in space? How do you calculate velocity without a time concept?
Have you actually looked at the big bang theory? What you describe is completely different to it.
The bit in bold especially, the big bang theory says nothing of the sort, not even close.
Do you have any suggestions on research then, specific to the big bang?
As far as i am aware big bang theory is that there was nothing and then there was a singularity which turned in to everything in the universe and it continues to expand to this day from this singularity. I was under the impression that the big bang theory did not account for the growth of planets or solar systems or galaxies. It just says that they appeared out of no where relatively close to its current state.
Wikipedia would be a good start, I'm not even being condescending, its great.
I wonder what the internet is like on the ISS, if they had gaming pc's could they play online FPS or would it to be too laggy? Actually they're very close to the satellite so it would be faster maybe?
