pfft - 1.55v or go home![]()
But I'm on air Lol. Max temp so far 78c running IBT very high.
But I'm on air Lol. Max temp so far 78c running IBT very high.![]()
Bin IBT - use realbench as a guide
I'd say thats good matt, i get around the same with my tridents in with cpu at the same clock, with these ripjaws running dual channel i'm getting around 18,000
So you get less for quad channel? I just ran it and scored 17,281 exactly. I will have another go and see if it goes up. My gpu score has gone down a few points though, not a lot but a few.
Lol i like to be careful, it's my first time.
I'd be happy with what you're getting for the clocks used. Kaaps Physics IIRC is around that at 5ghz. The fact you're coming in close to mine at practically the same clocks goes to show how you've timed up those sticks. The difference between our scores will be the higher OPS on my chip clock for clock
Yeah FS is a good test for memory efficiency. Have you checked what bandwidth you're getting?
I think i will be looking at around 17,500 maximum, maybe a bit higher if i get a good run @4.9ghz. I do wonder actually if i used all three red slots rather than the black one if i would get a slightly better physics and combined score. That was how it worked on my P8Z77 WS board with a PLX chip. Using the PLX lanes only got me a boost, at the expense of a slightly lower gpu score. Vice versa for using the cpu pci-e lanes.
