So I've purchased my first house, and I want to overhaul the house with new LED bulbs.  But need help on a few things.  There dimmable switches in the main bedroom, kitchen/diner and living room.  Now I'm not fussed on dimmable, so is it just a simple case of getting a standard on/off switch to replace the dimmable switch?  And is it then just a case of replacing the bulbs with LED bulbs?
Here is what I've picked so far on a room by room basis:
[[/snip]]
Thanks for your help!
I'm going through a similar thing my self at the moment but it's a bit of a nightmare to be honest!
I'd advise to buy a few at a time instead of all at once as some bulbs definitely have a different character to others; which you may or may not like- you don't want to end up with 50 bulbs you hate!
the superior 6watt COB GU10's I have from light rabbit have a very very nice quality of light to them, compared to the 60 SMD's I have from the same place which are a tad whiter but have that green cast that is very unfortunate. I have a number of IKEA LED's too; I quite like these; they're very warm and replicate soft/diffused glass incandescent bulbs quite well; I think they're decent value too.
dimming is a problem as I'm finding out at great expense. I bought 10* dimmable superior COB gu10's from light rabbit and have them set up as 4* on one fitting and 6* over two fittings. I've tried a varilight trailing edge dimmer and it can't really handle only having 4 bulbs in one fitting; it doesn't do well with the 6 either. I think if there were 10 or so on the dimmer it would be okay but until then it's just flicker mania!
on LR's advice I bought 2* Aurora retrofit dimmer modules (the green ones) and they're terrible! there's no way they add up to their own specs for running x amount of LED bulbs; replace one with a 50watt halogen and all the trouble goes away (still buzzy though)
in short; I don't think we're quite there with dimmable LED's unless you have 10 or more to a switch; even then they become very strobey when dimmed.
to replace a dimmer switch with a standard on/off switch will cost you about £2! so I'd save yourself the bother and do that instead.
as for fittings; as much as I hate these spotlight bars; I also dislike paying over the odds for fittings; so when it came to swapping the manky 50watt fittings from my kitchen I opted for these:
http://www.screwfix.com/search?search=luno from screwfix which will amaze you over how nice a light fitting you can get for your money...[upon getting that link I realise that they have jumped up in price quite a lot over the last week or so - they were £12 for the 4*bar and about £7 or £8 for the 3*fitting :S weird.]
