X79 Overclocking Guide
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
yh you can go higher imo,mid 80c is acceptable in stressing
cpu v I wouldn't like to run close to 1.4v or above on air,around the 1.38v would be my limit but upto you
Im on water, but using the pump and fans at the absolute lowest speeds possible. Im sure turning them up I could bring the temps down a decent whack, but aiming for silence mainly.
15 Dec 2004
Hudds, UK
There comes a point when that extra 100Mhz requires above average voltage increase. Thats the best point to stop for 24/7 use.
For example - I run [email protected] 1.26v for 24/7 as pushing to 4.6 requires jumping up to 1.32v which is an above average increase in volts - not worth it just for 100mhz.
