Morning all, I thought I would find somewhere to document this latest project on my car, while I am waiting on parts for arrive I have decided to take off the wheels and have a go at a diy refurb job to see what kind of finish I can get. If I mess them up then I am happy to get them done but I am trying to do more with the car and they need doing even if I plan on getting a second set so I thought why not give it a go. First off I went out and got all the bits I needed some of which I already had. Everything I am using is in this picture apart from the primer that I am using.
image post
Basically what I have is different grades of wet and dry from 80 grit right up to 2000 grit, filler primer, silver wheel paint, 2k clear, BodyAlu 2 part alloy filler, tack cloths and some mixing trays and applicators.
I started taking some pictures on the second wheel but the first one was far worse with damage almost all around the rim, either way ill get going with a few pics.
This is the second wheel as it came off the car:
You can see some pretty nasty damage on the edge of the rim.
First of all a good degrease and a wash, all you need here is some gunk and some warm water:
Mrs is away so I bought the wheel indoors for a bit of wet sanding:
free image host
here is the worst of the damage once sanded down a little:
Next up I needed to mix up the alloy filler, not sure on the quantity of hardener needed as all the instructions are in foreign so about this much seemed to go off pretty quickly:
Next up I applied the filler to the nasty areas trying to build back up the profile of the wheel, this is much harder than it looks, I am sure there is a trick to it, probably in how much hardener vs compound but this is what I ended up with:
After a quick sand back with 500 and working my way up to 1500, making sure to keep everything nice and wet:
You can see that there is still some raised areas so I decided to give the rest of the wheel a good key and go for a second lighter layer of the filler, sanding back again to give a nice smooth finish to touch:
And this is the two wheels I have prepped so far ready for primer:
Next up I masked up the first wheel ready for a coat of filler primer which I laid down in the back garden just as we were beginning to lose light outside, here is the finish of the primer on the first wheel, the worst of the 4 on my car:
And with the masking removed:
I am really happy that the profile of the rim all seems good again and is nice and smooth, I know the top coat is where it all matters so tomorrow I will be sanding back some of the filler primer with 2000 grit to get out any tiny imperfections before putting my silver top coat on.
I will update as I go.
image post
free image host
