- 26 Aug 2004
i7 4790K @ 4.8 GHz. GTX 780 Ti 1136 MHz Core. Not sure why my scores are lower than some of the 780s on the scoreboard.
Your lower Than my 780 but I had a 1215 MHz overclock but I am sure with some tweaks you will be way ahead of mine.
Heaven and Valley love Windows 7 and older drivers.
i7 920@ 2.66ghz
GTX 580 @ 800\2004
[Am I right that higher cpu clocks make little difference in this benchmark?
With fast cards the CPU clockspeed makes a huge difference.
If you run 3 or more cards it is pointless to run this bench at 1080p due to the CPU bottleneck. For best results 1600p or higher is needed.
cant see it?![]()
I'm in the ultra list?
Can't be right?
#1840 - 280X @ 1030/1500 - dtsrules
#1831 - 580 @ 800\2004 - easyrider
9 points less than a 280x with a GTX 580?
Your right, i just noticed your running 4x AA with it, shouldv' kept quiet![]()
