8Packs Ambient OC on Haswell E and 4ghz comparison with 4930K.
Watching with intrigue :)
Thanks for all your input 8 Pack....it is most helpful, and appreciated. :)
Thats why I chose it. No point in me pulling out my 4.8-4.9 ES which customers will struggle to reach. Lets test with the lowest bin to ensure all can and then show profiles on how to do this bare minimum.
yeh i appreciate it done this way :)
thanks for the compare!
Hi 8 Pack.
What kind of overclock can I expect from the 5960X when using a XSPC RayStorm D5 EX360 WaterCooling Kit?
That is if you receive the 5960X and it is a decent overclocker.
Thanks in advance for responding.
Silicon Lottery!!
I think average will be 4.3-4.4. Good is 4.6 and amazing is 4.8-4.9. Most I tested on dual where 4.3-4.4.
With these chips Uncore makes a big difference!!! So its important also. You get 4g Uncore and 4.4 this is like 4.6+ chip with 3.3 uncore.
Then memory is also important 2666 C10 and above your set.
High mhz you may loose like 50mhz off top end clocks but you gain more than this in efficiency. Most CPU can do DDR3000 with 32gb installed on RVE.
Great to read this, low bin performance is very refreshing, thanks!.
We can all dream of greatness but this is the sort of thing that helps sell me a product!
