The NC and VS fly around in gank squads on Miller, so you be fine.
As do the TR...
hi all
anyone know how to get rid of the FPS AND CPU osd on bottom left of screen
hi thanks how do I get rid of the cpu bottleneck ive got the new 5820kThis shows your Frames Per Second.
If it also shows CPU this means that currently its your CPU bottle necking your system.
If it shows GPU then its your graphics card.
Ideally your FPS should be around the 60 mark. In PS2 its likely to fluctuate between 35-60 depending on where you are, what your doing and how busy it is.
To remove the OSD press ALT+F. To get it back again press ALT+F.
If after pressing ALT+F your mouse/KB appears not to work press ALT again.
thanks very much for info being playing this for a long time and honestly never new about the FPS etcYou dont. Its just informative.
PS2 is a CPU intensive game that's not very well optimized for multi CPU systems.
You could be sat playing on a 64 core over clocked deathstar and you would still be CPU limited.
At a guess I assume most of the player base are CPU limited.
It can also be used as a guide, to inform you that you can increase some graphics settings. If your CPU limited rather than GPU then its possible theres some "oomph" in your graphics card not being used.
If your GPU limited, you can drop the settings, bit by bit. But all this will do eventually is move the bottleneck to the CPU.
Anyone got a good load out for a ground attack Mosquito?
Planetside 2: My Favourite Game Of The Past Two Years
Jim Rossignol of Rock, Paper, Shotgun, explains why PS2 is his best/favourite game of the last two years!
http://www.rockpapershotgun.com/2014/09/10/planetside-2-best-game/
I've been playing with the RPS outfit, they are a good set of guys, this is what makes the game more than anything.
