I've seen a cooler master 350D m-Atx case with 2x 295x2's and there was plenty of room.
I think they forgot that the bottom card needs a little bit space for the fan.
Assuming you can sort something out, how quickly will it translate to a price drop on the site?
Presumably the stock you have was bought at the higher rate so how does that work?
Not questioning Gibbo's hard work, but imo thats still pretty steep
Totally appreciate OCUK can only go so far, but even at £700 its nearly worth considering buying seperate cards and w/c yourself. Considering this should be cheaper being done by AMD /board partners......its pretty steap (and as a pre-order only/ one off deal even more expensive)
If you've already got water cooling and only need the blocks then two 290's overclocked well enough would match it, would still be close price wise though.
should realy have been made with options of 240/280 and even as big as 360/420 optionsNot questioning Gibbo's hard work, but imo thats still pretty steep
