**Official Mantle Utility/Application Thread**
30 Mar 2010
Under The Stairs!
Thought I would create a thread for Mantle enabled utilities/apps, so here goes, this thread will be updated when/if more Mantle enabled utilities/apps become available.
D3DGear http://www.d3dgear.com/ OSD FPS support only
D3DGear now supports Mantle enabled game title, only FPS feature is enabled for now.
August 8, 2014 Version 4.88.1888
Unfortunately it isn't free, it's a capture/broadcast app, there is a trial available so you can try it out.
Steam Overlay
Thraks@twitter
Steam Overlay now supported in Mantle games with the October 22 client update. :) Spread the word! Mantle support rolls on!
OSD FPS support only via D3DGear, but it's a start.
Trying it out, thanks Tommy :)
Thanks lads, and updated op.
Main tool I'm after is AB overlay, hopefully Unwinders on the dev list, Matts not giving up any sauce-his lips are closed tighter than an angry badgers backside.:p
