- 16 May 2004
- Derby
Hi guys. We are in the process of decorating the whole house. Done a few rooms so far and onto the living room currently. I stripped of pretty much all the wall paper and found the walls not 'great'. Paint-able, just.
Anyway, I thought why not have a go at plastering (skimming).
3 flat walls. One with a light switch, one with a plug socket and nothing on the 3rd one. Then the window wall which has windows believe it or not.
How hard can it be?
Popped to B&Q, picked up a bag of plaster, trowel, that thing that you put plaster on and some paint for later.
I mixed the plaster as per instructions and started to slap it on. Now, the first lot was ok and sorted of smoothed it with a even layer, then it sort of got a bit messy. By the time I reached the end of the first wall it was good again if I say so myself. I left it a bit and did another stage, juts with the trowel and no plaster, it smoothed it off. I left it a bit longer and mixed a bit more but slightly thinner to skim over the little gaps and ridges etc.. Did another skim with a clean trowel and its all nice and smooth.
Just waiting for it to dry to take a proper look and see if I need to do another light coat
For my first attempt I thought it went well. The next wall will be easier as I got the hang of applying it and a bit of a technique
A few pictures.. These were taken before I did final smoothing stage with clean trowel..
I would give myself a 7.5 out of 10 for this effort. It's actually quite rewarding doing this. Certainly going to save a few quid.
How hard can it be?
