AMD Radeon R9 295X2 Owners Thread
27 Jul 2014
Yeah think I am going to go for Alien isolation aswell as star citizen. Just 1 to go now.
I ordered the gaming keyboard, mouse bundle to so get sniper elite 3 too
Caporegime
30 Jul 2013
Finally installed mine after an epic battle to reconfigure my case to fit the blimmin Rad and Fan
In the end I had to turn my Cooler Master seidon 240m radiator around at the top of the case, and now I can't fit my Blu-ray drive back in because of the 240m radiator pipes
Small price to pay, I never really used the Blu-ray drive anyway.
23 Jan 2012
Mines still running bad I have tried a few drivers now, all the games are the same they are very jittery. Even with only one card running its the same, In unigine heaven with one card running I get a score of 2300 ish and with two cards 4 gpus I only get 2500 ish. even choosing low settings in a game its the same my specs below any help would be appreciated.
Gigabyte z87x-ud4h
i7-4770K @ 4.0
TeamGroup Xtreem LV 12GB (3x4GB) DDR3 PC3-21300C11 2666MHz
Samsung 120GB SSD 840 EVO SATA 6Gb/s
r295x2 4 gpus 2 cards
Silverstone Strider SST-ST1500
25 Jun 2011
Aberdeen
3x4gb, might be a start to remove one of those and get the machine running dual channel firstly, you haveone bank in dual and another in single.
20 Jul 2012
Manchester
Gigabyte z87x-ud4h
i7-4770K @ 4.0
I'm not sure if frame pacing works for quadfire.
25 Jun 2009
damn it...........those cooler pipes look short does it reach the roof panel and also....does it reach the lower front panel.........because my Lian LI is big :eek::eek:
12 Jan 2010
Cornwall
It lives!
What a mission to install it. I had to change the PSU too, but I didn't have enough room at the back for the GPU radiator, so it had to go onto the roof, which meant taking the case almost completely apart.
Still need to do some tests first.
Caporegime
30 Jul 2013
Anyone know why GPU-Z wasn't displaying the GPU load when I was running BF4? I had Mantle enabled but I doubt that made a difference.
Memory usage at 1080p with 150% resolution scaling got above 7GB! Ultra preset.
Caporegime
30 Jul 2013
Tried watch dogs at 1080p on my TV. Fps were dropping to below 30fps turning corners in the car.
Highest settings possible.
Is crossfire support worked in watchdogs? My 290x ran it better.
8 May 2014
france
hmm weird 4k in dead rising 3 eats 12gb of pagefile 6gb ram and 7gb vram...............Somethings wrong here! My 3gb 780s could just about run 4k in it albeit at 40fps.
mirored memory, it uses half that per gpu, beside dead rising 3 is a port, that was just released, gonna need patch probably, and driver to optimize, i doubt the game has multi gpu support, but any port from console to pc will be overboard memory usage anyway .
18 Oct 2011
What is everyone bios switch location? Mine is to the left. I get 100% fan speed when i first start my PC and cannot see voltage/fan speed in MSI AB.
30 Jul 2006
4090 on 850w = BOOM
With nvidia 2 x 780s it never showed the total just the limit of 3gb. With this 295x2 it seems to show both added together as some games use 7.5gb. Damn though! Deadrising 3 maxed out at 4k is not hitting the vram limit at all it's quite simply running terribly because only 1 gpu seems to work. Need a crossfire profile for that
Man of Honour
21 May 2012
Dalek flagship
Disabled frame pacing and removed a stick of ram and in heaven I now get around 3700 when benching, so thanks for the help I will have a good play with it tomorrow when I have more time.
You still seem a bit short of par
Here is a 1080p quadfire run with my cards (290Xs) at stock and a 4930k @4.0ghz.
What are your PCI-E slots running at
Does overclocking your CPU make any difference.
8 Sep 2014
Hi all.
Joined the forum today. Got my 295X2 through today, very excited.
Was worried about PSU load on the 12 volt rail so have gone for 1200w PSU.
I seem to be one of the few who ordered the 4K Iiyama monitor which also arrives tomorrow.
I expect my benchmarks will come in slightly under with my haswell 4770.
Seriously looking forward to the build, not looking forward to the electricity bill etc etc :)
26 Nov 2004
Carshalton, Surrey
Right managed to get mine squeezed in to my case fractal arc midi, think I may have to look at a new case as it was tight getting the rad in. Also they seemed to have made a massive effort to find the tiniest screws to use for fixing the rad to your case.
Other than that its a cracking card, and not much louder than my 290 at idle, a bit more noticeable at load but not by much, mine during firestrike didn't go over 66c with a score of 14411 with a i3570k @ 4.4 so not a bad score to start off with.
