Oscar Pistorius thread
almost 16?
16 wounds, but many are exit and entry and possibly a bit is shrapnel as well... It unimportant, the point is that firing a gun at a door doesn't automatically mean the shooter has intent or foresight that they will kill someone. There is insufficient evidence to show that OP knew he would kill someone and this is what the Judge has to base her judgement on.
Even though he thought someone was behind the door he was firing at?
Part of his defence was the fact that he thought the person behind the door was not Reeva Steenkamp.
Hence why culpable homicide is still available as a verdict, hence why the judge said who was behind the door is irrelevant.
Culpable homicide can be with or without intention to kill. It can simply be negligent. That is why it's still available and why the person behind the door in that context is irrelevant.
To illustrate that the amount of bullets fired doesn't necessarily mean you will kill someone or that the shooter has an automatically assumed intent to kill.
But i'm guessing you wasn't stood directly behind a door whilst being shot at upto 16 times? :confused:
Which is no point as the case is about the murder of Reeva not whoever (it was Reeva which makes it irrelevant) was behind the door. As someone pointed out, it was referenced as a point of fact, not a point of law.
So why, when the charge of the premeditated murder of Reeva was thrown out, was there still the charge of second degree murder to cover ( which was also later thrown out , and what I a disagree with)?
good to hear youre ok!!
i am struggling to grasp how firing a gun bears no intention to kill. isnt that what they do?
Weren't most of the shots also fired at waist level (as OP was on his stumps) as well?
I personally cannot envisage a situation where I would fire a gun more than once at someone if I did not intend to kill them.
Its a fairly ludicrous argument to suggest you would do so for any other reason.
Because she said that there was insufficient evidence to prove either premeditated (Murder One) or intentional (Murder Two). Next is unlawful negligence.
That's how I read it.
Law and reality don't always overlap though, unfortunately.
OP didn't fire a gun at someone. He fired through a door, where he believed an intruder was hiding. I concede that there's only a hair's breadth between the definitions, but they are important, nonetheless.
