Apparently the 285 does even better in Tessmark than a 290X, according to PCper, i could easily test my 290 against your 285 result Gibbo, in fact i will. brb
Would the CPU have an effect? the 8350 v 5930k isn't really a contest.
No idea if these scores are any good:-
Heaven 4.0 Extreme preset:-
That's a 285![]()
My thoughts exactly.
The 285 run on a 5930K @ 4250 with 32GB RAM
The 290 run on a 8350 @ 4515 with 8GB RAM
Could be down to CPU also
How long have you had your PSU? Also wondering, did you use any form of daisy chain on your 8 pin connectors?
Can someone tell me if this PSU is enough to power this thing:
http://www.thermaltake.com/products-model.aspx?id=C_00000982
It's served me well till now. Have installed 295x2 and 14.4 drivers, got a whopping 18FPS in Watch Dogs before system turned itself off. This means there is not enough power on each 8 pin connector, right? So long as I don't game it's working good.
PSU has 4 12v rails which total 62A (I'm useless with this stuff).
That PSU will fall flat on its face with a 295 X2, its multi rail and not single. No hope!
OK cool I need an upgrade anyway (partially modular = complete cable mess). So the bad FPS is because of low power input right? I hope so lol
Don't think it is down to the CPU, I only get 19k on a stock 290X using a 4930k.
Don't forget a GTX 770 is slightly better than a 285 on Tessmark. The increase comes from changes in the architecture from Hawaii to Tonga.
Tessellation is a small but welcome part of a cards performance, just because a GTX 770 scores double what a 290X can does not make the 770 the better card (but every bit helps).![]()
Hi there
AMD Technical have explained why this is:-
To provide improved geometry performance on the order of 2-4x the tessellation throughput we did a number of things
Compared to R9 280 Series:
• R9 285 can execute 4 primitives per clock vs. the R9 280 series which can only execute 2 primitives per clock (Quad Prim vs. Dual Prim)
Compared to the tessellation unit in the R9 290 Series we’ve improved performance through the following
• Larger parameter cache, backed by L2 read/write cache
• Improved work distribution between geometry front-end units
• Improved vertex re-use for better performance with many small triangles
In summary it was done through improved HW and as we do with each generation we are constantly improving our HW as the demands of new games continue to grow.
I hope this answers your question.....
This is going to be good when they put these improvements into their high end next gen cards as well.
Check and it's rated 83A on the 12volt rail - that is enough to run a 295x2 right?
Jesus Christ.....
My 290 @ 1100/1406 = 19672
Gibbo's 285 = 32912 (+65%)
Your 285 just destroyed my 290![]()
Heaven scores on my 290 are much higher though, i'm not sure its tessellation that gives Nvidia the advantage in it.
