If I can run Titanfall, What else can i play ?
8 Dec 2012
Hi all,
So having tried out the Titanfall on origin thanks to a free 48 hours i was surprised to see my little machine could play it.
im rubbish and reading recommended game specs so was wondering if I can play Titanfall at 50-60fps 1080 on medium what else can i play ?
Thanks
You can run any game you like. Some stuff will be at fairly low settings, but everything will work and perform at a very satisfactory frame rate (as long as settings are adjusted appropriately)
I've just fixed my mates old PC (Q6600, 4GB RAM, GTX 260) which is probably lower in spec than your machine and I've played Batman AC and Bioshock Infinite on it at 1080p. Batman ran quite well at mostly high settings, Bioshock defaulted to low settings but it still looked ok.
£80 or £90 I suppose.
Your GPU will play pretty much any game out there, but you would have to lower the settings substantially for some of them.
Assuming it is the middle-of-the-road model, the HD5850, a friend of mine had one until recently, and he happily played most games.
He said that he could run Crysis on medium.
