Permabanned
- 29 Sep 2011
- melee island
If you insist on Z97 then you might as well drop to an i5 for gaming.
Yes I agree the case is bland, but the NZXT cases look horrible to me. There are better cases to be had.
27'' at 1080p is too blocky for me when sat closer to the screen. Wether it is 60/120/144 it don't matter. The pixels are too big. If you find the same too, well, that is a big waste of your budget.
So you might as well spend half as much on a 22" 120/144 monitor, which is the sweet spot the screen looking less pixelated when you are sat closer.
You could spend £1500 on this and be perfectly happy for gaming, a much more bang for buck approach...
YOUR BASKET
2 x Sapphire Radeon R9 290 Tri-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-00-40G) £269.99 (£539.98)
1 x AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal £199.99
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £169.99
1 x Crucial MX100 512GB SATA 2.5” 7mm SSD + 9.5mm Adapter CT512MX100SSD1) £144.98
1 x Silverstone Enthusiast Bundle - Tundra TD03 Liquid CPU Cooler & Raven 3 Full Tower Windowed Case £124.00
- 1 x No Power Supply Required £0.00
1 x SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black £97.99
1 x Avexir MPower Yellow Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2CM) £89.99
1 x Gigabyte Z97-D3H Intel Z97 (Socket 1150) DDR3 ATX Motherboard £83.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
Total : £1,543.60 (includes shipping : £14.75).
YOUR BASKET
And say forget about including a PS4 in the discussion and just get a nice 1440p 60hz monitor and maybe upgrade it later. In which case I need I’m going to need a bigger desk!
