- 1 Sep 2014
- US and A
Stax SR-Λ -- extended impressions
Figure I'd post this here if anyone is interested.
My original post on reddit: http://www.reddit.com/r/headphones/comments/2gedoi/stax_srλ_normal_bias_extended_impressions/
TLDR: Electrostatics are nice.
Preamble:
What is it?
How does it sound?
Comfort and Build Quality:
Purely subjective rankings:
Other notes:
Pics:
Preamble:
- My sound preference: Generally on the warm and dark side of neutral
- Source used: PC --> Yulong D100 MkII --> Emotiva mini-X --> Stax SRD-7 SB (adapter box/step up transformer for speaker amps).
- Other headphones used: HD 800 / LCD-2
- Time spent with product: 7+ months.
What is it?
- Product link: http://wiki.faust3d.com/wiki/index.php?title=SR-Λ[2]
- Description: It's an electrostatic headphone first introduced in 1979. I purchased it off the for sale section on Head-Fi.
- What do you get: These were bought used so all I really got was the headphones themselves and adapter box (bought as a bundle).
- Price: 350 EURO shipped (used item)
How does it sound?
- Bass: Surprisingly the SR-Λ actually doesn't do too bad in the bass department. Extension is reasonable and there is a decent amount of punch though lacking in both areas when compared to the LCD-2 and a bit behind the HD 800 (Anax 2.0). Does in rare cases exhibit some low end break up/distortion, most likely due to the driver age/wear.
- Mids: If it wasn't for the slight harshness in the upper mid range, it would be almost perfect. Definitely not recessed in any way, not as lush/thick sounding as the LCD-2, gives an incredible sense of speed and detail.
- Treble: Doesn't seem overly prone to sibilance though I have noticed it on occasion. Not as bright as the stock HD 800, definitely brighter than the LCD-2. Typical electrostatic levels of detail and air.
- Soundstage: HD 800 still wins hands down in this department, SR-Λ is noticeable more spacious sounding than the LCD-2.
- External Isolation: Non existent, you can hear your dog fart from across the room.
- Overall: Fairly 'natural' sounding headphone, slightly harsh in the upper mid range, with some insane transient performance.
- Headband: Great, plenty of room for adjustment even for my large noggin. Headband is of the suspension type design. The material is some kind of very soft fabric (not leather), the headband arms are made of plastic. It's probably the most comfortable headband out of all my headphones.
- Ear pads: The shape is rectangular with an oval cutout for your ears. There is a slight angle making the headphones sit slightly forward. They are large and easily fit around my ears. Depth is a bit shallow (though the drivers sit back in the housing so your ears won't touch them) and padding is a bit meh (I suspect the foam inside has degraded). They use some kind of leather/pleather material for the covering, feels ok, definitely not the nicest pads I've tried.
- Cable and connectors: Cable is the typical ribbon type that Stax tends to use, they are soft to the touch and in pretty good condition. They exhibit pretty much no microphonics at all which is great. The cable itself is pretty bloody long (at least 2m). It is terminated on one end in a 6 pin connector (modern Stax headphones use the 5 pin connector).
- Clamp: Very light, closest headphone I can think of with such a light clamping force would be my MA900.
- Weight: Decent, the headband really distributes the weight on your head very well so they don't feel all that heavy. The cable on the other hand does feel a lot heavier than what I'm used to.
- Durability: Considering these headphones are more than 30 years old I'd say the durability is reasonable. No doubt these have been well looked after but still 30 years is a long time. The cover over the diaphragm does show signs of degradation, and the ear pads and headband both show a bit of wear. They do feel rather flimsy when you hold them being made almost entirely out of plastic. Not something you'll want to just throw around.
- Bass impact: LCD-2 > HD 800 >= SR-Λ
- Bass extension: LCD-2 > HD 800 > SR-Λ
- Bass enjoyment: LCD-2 > HD 800 > SR-Λ
- Mids lushness: LCD-2 > HD 800 = SR-Λ
- Upper Mid range harshness: SR-Λ > HD 800 >> LCD-2 (most harsh -> least harsh)
- Mids enjoyment: LCD-2 >= SR-Λ = HD 800
- Treble air: SR-Λ = HD 800 >> LCD-2
- Treble enjoyment: SR-Λ = HD 800 > LCD-2
- Soundstage width: HD 800 > SR-Λ > LCD-2
- Imaging: HD 800 > SR-Λ > LCD-2
- Headband comfort: SR-Λ > HD 800 > LCD-2
- Earpad comfort: LCD-2 > HD 800 > SR-Λ
- Clamping pressure: LCD-2 >>>>> HD 800 > SR-Λ (more clamp -> less clamp)
Other notes:
- Amping: Being an electrostatic headphone it needs a compatible amp to go with it. I use the SRD-7SB attached to the speaker taps on my mini-X. Seems to do a decent job of driving them (I have the volume knob set at about 11 o'clock on the mini-X), it does take a few seconds at the start to build up the necessary charge (i.e it sounds quiet and the bass is non existent). On a side note, it can be quite hard to find amplifiers for the normal bias range (230V compared to the current 580V). When you do find one, they are usually still quite expensive.
- Driver wear: Due to having such a light/thin diaphragm, the older Stax models can be rather prone to driver wear/damage (moisture and dust on the drivers seem to be the main culprits). My pair seems to be in pretty good shape, the gold covering over the diaphragm does show a few dark spots but apart from the rare bit of break up/distortion on some bass notes, it seems to be working fine.
- A word on soundstage and imaging: I find it quite hard to accurately judge soundstage differences so be aware that like everything else above, I could be full of schiit.
Pics:
- A few more: http://imgur.com/a/qTcaD
