Hi there
OK sorry for the miss-leading thread title but this is new LG's monitor designed for gamers and it looks pretty damn impressive:-
LG 24GM77 24" TRUE 144Hz Widescreen LED Monitor - Black /w Flicker FREE Technology @ £269.99 inc VAT
For the smoothest gaming experience, MOTION 240 creates an effect similar to changing a frame 240 times and eliminates afterimages whilse minimizing motion blur. It also improves response time and delivers ultra-smooth playback by performing at a speed faster than 1ms, the speed that gamers are looking for.
A Dynamic Action Sync Mode, make real-time commands and strike fast. Gamers can catch every single moment in real-time with dynamic action sync mode. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag. Make timely commands to win!
A Black Stabilizer, enhanced gamer visilbility to win in pitch black areas. Black stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
A Convenient game mode and game pad. Quick and easy customizable settings for your perfect gaming display environment.
Features:-
- Gaming without blurring and ghosting with "Smooth Motion"
- Detect enemies one step faster with "Swift Action"
- Personalized gaming environment with "Rapid * Easy Settings"
- Motion 240
- Dynamic Action Sync
- Black Stabilizer
Specification:-
- Height adjust and swivel stand.
- Back Light Unit: LED
- LCD Size: 24"W
- Vertical Refresh Rate: 100 / 120 / 144Hz
- Aspect Ratio: 16:9
- Resolution (max.): 1920 × 1080
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170° / 160°
- Response Time: (Tr+Tf) typ. under 1ms (GTG)
- Display Colors: 16.7 million
- Input / Output Connector: D-sub / DVI-DL(Dual-Link) / HDMIx2 / DP1.2 / Headphone jack / USB Hub
- Flicker-free Technology: Yes
- VESA: Yes 100x100
- Warranty: 3yr
Only £269.99 inc VAT.
ORDER NOW
Features:-
- Motion 240
- Black Stabilizer
Specification:-
- LCD Size: 24"W
- Panel Type: TN
- VESA: Yes 100x100
- Warranty: 3yr
ORDER NOW
