Mine's now running happy along at 4.5 @1.320, but memory is at default (2133), would be nice to run it higher but it's still early days.
I have decided to swap this UD4 out for the SOC though and rehome the system is a white Luxe.
Can peeps with i7 5820K, 5930K and 5960X plz post their highest stable overclocks.
We can get a rough idea of what performance is attainable in a home users PC.
Cheers.
Good idea, when people do, can you post up in the OP?
Can one of you with an ASUS board do a favor?
Load CPU-Z twice (motherboard screen and CPU speed screen) visible, run 32M Super-pi and while its on say loop 1 or 2, hit print screen and upload here.
So basically pic of desktop with 2x cpu-z and super pi open and visible and a bit into a run of 32M.
Another thing i've noticed is that my max overclock on my 290X has dropped an awful lot.
from 1270-1280 to around 1200even with the Blck @100.
I have the same bloody low physics bug with AMD and benchmarks, it's an issue with powerplay, only way to kinda of fix it is enable "without powerplay support in AB.
Only that crashes the system now, at this rate i'll be going green soon.
Broomstick - Can you add voltages as well, would be helpful for expectations.
here you go
http://i1370.photobucket.com/albums/ag249/jimbaw/superpi_zpsf225d057.png[/IMG[/QUOTE]
I should have said,
Stock/default settings please.
