- 2 Jan 2012
- UK.
New bios out including UD4, F9C, still can't run my ram using XMP profiles with any sort of overclock, but managed to get it running @2666 with the cpu @4.5 +250.
Thanks mate, will update
All the X99 chips seem to be reaching 4.5Ghz comfortably. With a few chips capable of 4.7Ghz > 4.8Ghz with quite a lot of volts and very good cooling.
It's still early days, so hopefully with improved bios / better memory compatibility things will improve a bit as well.
Weird problem, just updated, now I can't into bios
I can boot to Windows no problem, everything is running fine, but if I press DEL on boot up to enter bios I just get a black screen?
Oh the joys of early adoption !
Got this quite often on the boards Ive returned too, part of my general video issues ( along with extremely long times just to get to bios splash screen)
Its killing me having a 5820k I cant do anything with until the refund comes through lol
I hope you get it sorted asap bud, my UD4 has been "ok" these last few days tbh, but still going to get the SOC instead.
@born to kill try a lower level loadline calibration or set cpu voltage to normal and use a negative dvid to undervolt or reduce cpu voltage further
ohh for msi Idk
try looking for cpu offset and reduce it
Cheers guys, yeah still no joy. I'm going to try and remove the battery, or is their easier way to reset cmos?
Will replace the memory in different slots etc, try and get to go into bios. Not gonna get a chance to try things out until tonight. Weird because it has been fine up until past couple days, I think this happened before the update as well, I just didn't think anything of it as I was running an OC and didn't want to change settings only turn the fans down. Since then I've updated and cannot get into bios at all. Black screen every time.
Still running fine within Windows, really weird, not had this before lol.
