- 7 Jan 2013
Take it the performance between the two is similar then? But you reckon I should switch it out?
there are loads of reviews out there for you to make an informed decision on.
980's are more powerful and do produce better results however you need to put a value on that and decide if you require the extra 20+ fps or so. reading reviews and comparing benchmarks are the only way forward.
You could actually buy 3 970's cheaper than 2 980's.
Don't take this the wrong way, but those settings must look so bad it's unbelievable. You will have such blown highlights, dark crush and loss of detail going on, the mind boggles.
No ones runs a monitor at 100% brightness either (unless you mean specifically for using ULMB mode only?)
Look at all the reviews and calibration reports. Most set the brightness to between 20 and 30 to get the right/ best settings.
If you're starting from nowt, 2 x 970s seems to be the smart buy now.
If you've got a rog swift, you need to get nvidia dude. I've just got one yesterday.
I appreciate your input guys. I do think i'll go with 2x 980's because I don't think the environment in my case without liquid cooling would suit 3x 970's if i'm honest.
As you seem to be more clued up then me (admittedly I'm noobtastic when it comes to monitors and setting them up) care to share what settings you use for me to try? I have backed off monitor brightness to 40 and moved some other settings about, not as much glare from the screen but colors do seem deeper.
Nooooooooooooooooo, 970s, end of
/questions
So I'm suddenly getting black screen with 'out of range' coming up when trying to fire up games and can only use windowed mode. I have not changed anything. Was working fine this morning. No driver update. Anyone else getting this?
Did a quick check and my MSI Z97 Gaming 5 supports only 2 way SLI. So it looks like it's 2x 980's for me unless there's a way round it?
Despite only ordering at around 15:50 yesterday I've just got confirmation that it's being delivered today! Rather epic service from Overclockers to get it to the courier in time (I think the cut off is 16:00) and assuming it does arrive equally epic from DPD for delivering on a sunday!
ULMB should default to 100brightness, and i use pulse of 30-50 depending on map for BF4, that one map where you're in the tunnels is too dark to have the pulse low.
Your decision and the 980s are sweet. I was taking into consideration that the 970s were close to the 980s and looking to save you a few quid.
. However it's still tempting to go 2x 970's because they are quite close and cheap, so still haven't made a rock solid choice yet
