** MASSIVE NVIDIA PRICE DROP!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Had news from NVIDIA this morning that they shall be price protecting all our inventory to reduce prices on all 760 and above graphics cards tp clear stocks out!!
GTX 780Ti from £349.99 Inc. VAT
Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) @ £349.99 inc VAT
GIGABYTE, the world leader in high-performance gaming hardware and system, is pleased to announce the latest graphics card, GeForce GTX 780 Ti Overclock Edition (GV-N78TOC-3GD). With 25% plus CUDA cores than GTX 780, the most powerful thermal design in the world and exciting new technologies, GV-N78TOC-3GD is going to bring all the gamers an extremely gaming experience to a whole new level. The exclusive WINDFORCE 3X cooling design guarantees you to dissipate 450 watt heat out. Enjoy your game play with a stunningly beautiful and quiet design is no longer a dream. It also supports OC GURU II and GPU Boost 2.0 for maximum clock speeds. GV-N78TOC-3GD features PhysX® and TXAA™ technologies for smooth, sharp graphics, and GeForce ShadowPlay™ to capture all your greatest gaming moments automatically. Whether you play on 4K monitors at extreme settings, GV-N78TOC-3GD can provide the horsepower to drive all your next-gen gaming visual experiences.
GIGABYTE innovatively presents WINDFORCE 3X 2-SLOT cooling system, thinner and cooler! The thermal structure contains three ultra quiet PWM fans, an only 2-slot height heat sink with exclusive "Triangle Cool" Technology, two 8mm and four 6mm cooper heat pipes and a high-performance RAM heatsink.
The innovative thermal design guarantees the heat dissipation capability to over 450watt. The cooling performance is 14% significantly better than stock fan! WINDFORCE 3X 450W cooling system not only provides an effective heat dissipation capacity, but also gained a higher performance with lower GPU temperature through the GPU Boost 2.0 technology.
According to the latest NVIDIA® technology, GPU BOOST 2.0, GV-N78TOC-3GD provides gamers an unlimited overclocking capability. By using GIGABYTE exclusive OC GURU II, gamers can monitor and adjust all important settings such as GPU clock, memory clock, fan speed, voltage, power target, OSD and online support. With the upgrade and easy-to-control user interface, GIGABYTE OC GURU II becomes the best mate while using GV-N78TOC-3GD.
Specification
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£499.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780Ti GHz Edition 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TGHZ-3GD) @ £369.95 inc VAT
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
8-Phase power Design, compare to reference 6-phase power design, GV-N770OC-4GD V2.0 makes the MOSFET working at a lower temperature and provides more stable voltage output. Besides, over temperature protection and load balance to each MOSFET can effectively extend the card life.
Specification:-
- GeForce GTX 780Ti
- Core Base Clock: 1085MHz
- Core Boost Clock: 1150MHz
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£569.99] Inc. VAT
Only £369.95 inc VAT.
ORDER NOW
View entire GTX 780Ti Range!http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=1402http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=1402
GTX 780 from £227.99 Inc. VAT!!
KFA2 GeForce GTX 780 3072MB PCI-Express Graphics Card - OEM (78XNH5DN9IST) @ £227.99 inc VAT
The next generation GeForce GTX 780 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Core Base Clock: 863 MHz
- Core Boost Clock: 900 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
- Hexus Review: http://hexus.net/tech/reviews/graphics/55577-kfa2-geforce-gtx-780-sli/?page=12
Was [£299.99] Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
Vew entire GTX 780 Range!!http://www.overclockers.co.uk/productlist.php?catid=1914&groupid=701&sortby=priceAsc&subid=1341http://www.overclockers.co.uk/productlist.php?catid=1914&groupid=701&sortby=priceAsc&subid=1341
GTX 770 from £179.99 Inc. VAT!!
KFA2 Geforce GTX 770 2048MB GDDR5 PCI-Express Graphics Card - OEM (77XPH6DV6KVX) @ £179.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1046MHz (GK104)
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
- Product Review: http://www.guru3d.com/articles_pages/kfa2_geforce_gtx_770_ex_oc_review,23.html
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
View entire GTX 770 Range!!http://www.overclockers.co.uk/productlist.php?catid=1914&groupid=701&sortby=priceAsc&subid=1750http://www.overclockers.co.uk/productlist.php?catid=1914&groupid=701&sortby=priceAsc&subid=1750
GTX 760 from £145.99 Inc. VAT!!
KFA2 GeForce GTX 760 EX OC 2048MB GDDR5 PCI-Express Graphics Card - OEM (76NPH6DV8RNZ) @ £145.99 inc VAT
The KFA2 GTX 760 EX OC is the next generation high-performance graphics card featuring a up rated cooling solution with a custom twin fan design, meaning even more overclocking potential with improved noise levels and overall cooling even when under load.
Feature-rich and stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, GFE, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Specification:
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1084MHz
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: naMHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Card Dimensions - Length X Width X Height: 268*124.3*41.5
- Warranty: 2 Years
Was [£169.99] Inc. VAT
Only £145.99 inc VAT.
ORDER NOW
View Entire GTX 760 Range!http://www.overclockers.co.uk/productlist.php?catid=1914&groupid=701&sortby=priceAsc&subid=1830http://www.overclockers.co.uk/productlist.php?catid=1914&groupid=701&sortby=priceAsc&subid=1830
NVIDIA are clearing stocks world wide and are giving the world six weeks to have all inventories cleared after which time they shall remove this support. So if you want a deal on a 760 or above you've got six weeks to make your mind up, but of course stocks could sell out way before then, so don't hang around. :)
8 Apr 2014
West Country
Wow!! great news for guys who want to Sli:cool:
It's like Nvidia have had a personality change:D
... just think a week ago we would never have used the terms 'Bargain' or ' Price Drop' in the same sentence as Nvidia:eek: shows how things are suddenly moving quickly:)
OcUK Staff
OP
17 Oct 2002
OcUK HQ
I expected the 760 to drop a little lower than this. Great prices on the 780s though
Why?
Perfect price lineup now.
750Ti @ £99
760 @ £145
770 @ £180
780 @ £225
970 @ £260
780Ti @ £350
980 @ £430
NVIDIA have perfect price lineup now! :)
21 Aug 2006
At those prices I'm tempted to pick up a second 770 for sli and I don't even have an sli motherboard!! :D
Why have they priced the 970 so nicely? I remember buying my MSI GTX 770 Gaming close to/at (?) launch for £330 :eek: Did Nvidia make massive advances in the manufacturing that saved them a heap of money?
29 May 2012
Dorset
Why?
750Ti @ £99
760 @ £145
770 @ £180
780 @ £225
970 @ £260
780Ti @ £350
980 @ £430
With the 770s around the 180 quid 280/85 price mark I expected to see the 760s to be around the 270 area which is about 125 quid, may seem silly squabbling over 25 quid just thats what I expected
