Guys what sort of desk lights do you use?
I have a desk type lamp from ikea but use a big daylight energy saving bulb.
@ pieman109,
What no pre-shading? Is it not something you normally do then?
Did you not consider doing the invasion stripes prior to camo the masking off? Or is there a scale issue.
just wondering.![]()
Robby, the Robot, coming together nicely!
Robby[/img[/QUOTE]
When you finish could you get him to knock me up 50 gallons of fine bourbon :p
You don't have to use black but the undercoat is critical to how alcad paints come out. They are not paints as such, think of them more as a metallic clear coat. Any imperfections or blemishes will be picked up and magnified. If you want a highly reflective finish then you need a high gloss black base coat.
Below us a 1/72 mustang I painted using alcad polished aluminium. By using a mid grey base coat I was able to create a lighter , more weathered effect. PA on black base looks too dark in this scale
Guys where do you buy paint? I want to get few spray cans for my first build.
/\ Great models btw.
thank you![]()
Have you used the Tamiya spray yet?
Thank you very much.Your first order has a discount already applied to it and if you visit their facebook page and scroll down to their 18/09/14 post, you will find a other discount code to use.
Can you suggest what primer to buy? Normal or fine? Im looking at Tamiya.
I bought an inexpensive and easy model to build and to paint to begin with, Tamiya 35065 Panther.
But I do have big plans for later![]()
