Caporegime
- 18 Oct 2002
That will be why there is a good difference between your temps
Not really, I have a fan at the bottom of my Fractal blowing up at the bottom card
Also Chris, get thee sig changed
Xraycat, I've settled on very similar clocks to you at the moment - 1460core and +200 on the mem but that's without touching the voltage. If I can get to 1500core for 24/7 with a little fiddling then I'll be more than happy![]()
Yeah it froze half way though with 2000mhz @ +20mV plus artifacts gah
You checked what it's boosting to? 1460 boost on the 1st tab of GPU-Z isn't what it actually boosts to. Should boost to around 1560mhz in a game or benchmark.
Try +87mv, if it works lower it till it crashes then raise it to the voltage that worked. Or just leave it at +87 like I do lol.
Won't that require a lot of power or be bad longterm?
Thinking I should have ordered non-reference cards now if they run that coolWell I installed my pair earlier and I'm really impressed! Ran Heaven for 30mins to test stability/temps and the top card gets to a max of 68c and the bottom one 62c
This is in a Fractal Define R4 too which is very well insulated, you can't imagine the awesome silence to boot!!
Very very happy, a seriously powerful and silent system![]()
Getting my 970 this weekend but not sure which one to get as I'l be water cooling when the blocks are out.
Any ideas which card will be the safest option for me to buy in terms of full cover block compatibility?
Nice one Jedi! I was wondering whether I should have gone with the ref models but went for the MSIs. My pair should arrive sometime today. Cannay wait![]()
