eteknix have an update about the EVGA cooler - http://forums.overclockers.co.uk/showpost.php?p=26945430&postcount=662
Check out the 3rd heatpipes open end.
That's quite a balls-up.
Why would you go to all that trouble to put a "dummy" heatpipe in there?
Very bizzare![]()
Theyve reused the cooler from a kepler board without any modification, as the third pipe doesnt contact the chip they didnt bother filling it, it reeks of cost cutting and you end up with poorer cooling than even the reference cooler
Is that the ACX 1.0 or the ACX 2.0?
Either way, pretty shoddy. I was thinking of getting the EVGA cards as well..
I was planing on x2 EVGA 980's with this ACX cooler upon release! Besides it is a balls up in terms of engineering/pride, i don't think it will make any difference to the cooling performance.
In acx 1.0 they didnt even have copper cooler direct contact, it was just a lug of nickel coated something.
The EVGA's are awesome for the price for SC if you want to toss the cooler off and use water cooling.
Was going to pre-order 2 x 970's till I noticed the price increases across the board, some at almost 10% higher.
Yes the new cooler design is very innovative and doing its job very well.
