Hi there
A few more hundred of the MSI 970 Gaming arrived this morning, so now we should not run out over the weekend.![]()
That'll be coil whine. Happens on most cards, but your psu can also have an impact on the extent of the noise as well.
My Galax OC 970`s never go over 55c on max OC 1500/8000. Default Volts.
Anyone got their card / cards under water yet? Piks and benches please![]()
Only just seen this. Followed your recommendation and ordered 2 of these, so by tomorrow I'll have 2xMSI and 2xEVGA. I've filled in an RMA request for the EVGAs based on the noise. Hopefully I won't have any problems returning them.
This is OK by me and I've updated our descriptions on the radial blower designs stating they are not quiet.
The EVGA should be quiet so I can only assume the fans are faulty, so a return is no issue, any issues point them to my reply here.![]()
Just got a reply... basically saying if I want to return them under DSR there's a 20% restocking fee. So I lose about £120...I don't know about what they are like compared to the reference cards, but the EVGAs are considerably louder than all of the other cards that I have seen in reviews. I believe the review found that the EVGA at idle was louder than the MSI or Asus under load
At about 60% its difficult to focus on gaming... at 70% its unbearable... is that enough to return them for the MSIs? Keeping in mind the fans are always above 60% when gaming.
I've took the +87mv off mine and running it at 1500/2000 stock voltage with 110% power and priortised for temp. This way GPU-Z tells me the PerfCap reason is Vrel which means more voltage required, if I add voltage it then splits the PerfCap reason between Vrel and VOP which means more power is needed and for some reason the card will throttle to lower clocks and voltage. Not quite sure what's going on to be honest. Afterburner might not support these cards properly yet.
Yes been playing around with volts same issues not really making any difference for me so I just use defaults and still hit 1500 on the core. Using the Galax OC 970. It would seem something is not working either AB 4 or a Bios issue .
Does anyone know why my MSI 970 makes a buzzing sound when it's under load? It's definitely not the fan as I have used afteburner to turn the fan upto 100% and it doesn't make the buzzing sound
use the empty bog roll method to make sure whether its your GPU or your PSU. I thought my 770 had coil whine until I read about using an empty toilet roll as an ear trumpet and it wasnt my GPU it was actually my PSU making the coil whine.
Its probably your PSU either way.
Didn't have much time last night as it was pretty late but I did a light overclock.
MSI GTX970
+200Mhz on the core = 1558Mhz boost (I think)
+200Mhz on the memory
No extra power limit or mv. Got me 60.3 fps on heaven. Card hit a max of 51c at 100% fan.
ASIC was around 75% on my card.
Anyone use this cards with ROG monitor? What about fps at games? I am not sure buy this monitor or no... i think no, because i cant reach 140 fps for 140 Hz
