So that they have your e-mail address for sending adverts about their ROG products?
100% correct.
you'll be fine aslong as you buy from reputable retailer and not one that cba to rma to asus
asus are difficult but you mustn't give in
This is 100% correct.
Always use a reputable retailer when buying Asus products. The RMA service for components is dealt with via the retailer. If you have purchased from a back street retailer you will run into issues.
Please remember my problem was with a motherboard and nothing else.
Motherboards aren't repaired in the UK. This and other communication / consumer law problems made it difficult. Not to mention Asus wanting the retailer to deal with the problem. I don't think you should have anything to worry about.
I see. Are GPU's repaired/replaced by Asus from within the UK?
