Man of Honour
- 20 Dec 2004
- Tamworth
all I did was
1.open GFE
2. Look at their Optimal settings (ones suggested by GFE) it just shows your resolution no DSR symbol.
3. click the resolution itself & up pops a box with the resolutions Select the resolution higher that yours, apply it
run game. if you see my video you'll see that its in 4K I only have a 2560x1080 monitor & Afterburner states 99% on both cores
hope it helps
I have 10 minute shadowplay video proving the gfx setting 4K maxed I can upload that tonight if you wish
I sort if did that, but I was clicking on the spanner icon and I could only choose resolutions upto my monitor's maximum. After I disable SLI I could choose higher ones.
I'll try just clicking on the resolution when I try agin.
