The ETA for the Inno3D X2 shows as Friday, Is that pretty accurate? So if I order a pair for Saturday delivery I should receive them on Saturday?![]()
I quite fancy getting two of those.
Not sure how quiet they will be though.
What's great about the Asus? I only ask as I'm looking at getting a 970. I like to the look of the gigabyte although people reporting its a bit noisy at idle is putting me off.
People are missing out on a phenomenal card if that's the case.
I have to ask, you have an ASUS MB do you not?
Well this may be a round the houses way of looking at it, but it appears to be an upgraded version of the cooler they used on their 660ti, that cooler seemed to have good noise/performance at the time, matching the MSI TwinFrozr IV. This new cooler has bigger fans than the old one so should perform even better, and the GTX970 has a 5w lower TDP than the 660Ti did so its basically a better version of a cooler than did well on a very slightly warmer card.
Ironically both my previous encounters with Inno3D involved SLI, Voodoo's and 9600's lol.
The HerculeZ coolers have a fantastic reputation for low noise and are very powerful coolers.![]()
Not seen the two fan one in action though.Yeah I have the 780 Ti Herculez and it's greatNot seen the two fan one in action though.
Just ordered the Zotac 970 and EK FC670, should be here Friday.
I bought the MSI GTX 970, and am very impressed. I had a Gigabyte 560Ti previously, so it was a big upgrade. There's a difference even when playing old games like World of Warcraft. I have an Intel 2500K cpu, and 8gb of ram.
A feature I like is that the card has a smart fan system, which controls fan speed, and therefore noticeably reduces noise. The card fitted without issue inside my Silverstone FT02B case.
Yess. Very small...Any reviews of the Zotac one, that's really quite small?
The JetStream is apparently quieter than the MSI but runs around 7C hotter.
I do really like the look of that Zotac.
I have a problem with one of my MSI cards
When i try to switch fan to 100% at first card start working only one cooler, what i need to do? return card?
