So... my amplifier just exploded!
6 Mar 2008
Stoke area
The capacitors (i think) holds powers for hours even after it's unplugged.
Just leave it for a day before you open it up.
yeah I had the same advice with a SKY+ box...
Left it unplugged for 2 days, took the case off to remove the HDD and touched something underneath.. BANG
Burnt a hole in my finger and had a dead arm for about 3 days :(
happened at 3am as well, could have been lying on the floor for hours until someone found me!
OP, Bin it/get a pro in to look at it/insurance job... I wouldn't bother trying yourself unless you really know what you're doing and I betting you don't :D
1 Dec 2004
S.Wales
Touching capacitors, doesnt seem like the smartest idea, its not A) going to fix the amp, B) Going to fix your emotions after a negative day :p
20 Feb 2009
Not where I'd like to be
There a place in town I can get it repaired so taking it there in a minute.
Picture of the insides. Nothing looks like its burned out or damaged...
http://i.imgur.com/TiZdgyW.jpg
http://i.imgur.com/YkAfOem.jpg
http://i.imgur.com/lteHXiL.jpg
http://i.imgur.com/MbpmMHe.jpg
Yeah but your torque range bolovating unit has gone as well as the thingamajigs and I can't get the parts till a week next Tuesday and then I'll hand it over to the YTS lad we just got and it'll be good as new.
20 Feb 2004
Blyth, Northumberland
Man of Honour
29 Mar 2003
Stoke on Trent
One of my Mackie SRM450 PA speakers blew up on stage last night so we stopped the gig, replaced it with a stage monitor that surprisingly did an excellent job and will be used again tonight.
I've just bought two more for a steal and I'm going to collect them tomorrow morning.
Oh and yes I have tried turning mine back on with the board out of the speaker enclosure but it's dead.
29 Mar 2011
Take the board out and flip it over and find the short. Sounds like a cap but yours look ok.
The will be somewhere on the board a blacked area where it blew. Then just trace from there. Nothing goes bang without leaving a mark! ;)
23 Nov 2004
Although the main caps (purple) on these amps can blow very spectacularly, they also go dead short with no other signs of failure.
Check Q703 and Q702 which are thyristors that are mounted to the heatsinks at the bottom left of your second picture. If a cap is short then one of them is likely to have blown its top off.
Also, as itchy said, check underneath for blown printed circuit track.
