I picked up a 6+ today having owned the 6 since launch day. I'm struggling to decide which to keep and which to return, they're both great phones but both have their pros and cons (as I'm sure has been said countless times in reviews). I have until Friday to decide, but so far in my opinion:
6+ pros:
- Obvious one, screen size. Things like safari fit more on screen and small web fonts are more easily read without zooming. Apps that have been updated look excellent with far less scrolling required in general. Talking of the screen though the viewing angles and contrast seem just the tiniest amount worse than the 6.
- Battery life seems to be around 150% of the 6 based on my one days testing.
- Videos and games are far more enjoyable on the big screen,
- OIS, although as below I've found no noticeable difference yet.
6+ cons:
- Most scaled apps look really bad. Noticeably worse than the 6 which doesn't have to 'scale' as far. Hopefully this problem will eventually go away, but I'm sure there are apps that will never be updated or that will take forever, this seemed to happen when the 5 was launched too.
- Interface lag. It definitely suffers more than the 6 here. 90% of the time there is no lag on either, but then the majority of my apps are yet to be updated to run at native resolutions. When this happens, it could become more of an issue. The 6 runs the same image resources as the older retina devices (4S/5/5S etc; @2x images). whereas the 6+ loads @3x resources. As the 6 & 6+ are running the same CPU and GPU, the plus has to work harder not only to drive the higher pixel count on the screen, but with increased asset sizes too. To compound the issue, display output is actually rendered at 1242x2208 rather than 1080x1920 and then downscaled.
- One handed use can be difficult. The 6 is relatively easy to use one handed.
- 'Pocketability'....
6 pros / cons are of course a mirror of the above.
Other ramblings:
I find the 6+ landscape mode within apps like mail, messages, notes etc useless. Honestly does anyone type on that god awful landscape keyboard?!
I tried but am yet to find any difference between the 6&6+ cameras, despite the OIS. I took a bunch of photos in low light and they both do a reasonable job there was no noticeable difference really.
Both are a good upgrade from my current 5S. The 6+ looks comically large next to a 4S......
