*** The Official Destiny Thread (now includes 2.0 and TTK) ***
I never knew that was an effect in PvP!
My Bad Seed pulse rifle have the ability to make enemies flinch more - only thought that's useful in PvE, so always switch over to quick scope when doing PvP!
Might need to try and see if it really makes a difference.
other way round, there's one that makes you flinch less when being shot at.
The mod is called "unflinching" and says this : "its easier to aim under fire using this weapon"
Any tips Rabbit?
ps3ud0 :cool:
Watch out for the psions 'psychic wave' attack, other than that its business as usual. The majority of the psions durability comes from its shield, so just have a void weapon handy when you face them. The majority of the strike can be skipped, so you only really need to contend with the lieutenants and the final boss. Also, don't get kicked from the servers :p
Is it the one with the tank? Always struggle on that one :(
Cheers dude - no doubt Ill catch you on on PSN later - let me know if you get past it. Was assuming it would be psions and arc damage that could be a pain. Ill bring my sniper!
Yep just deal with the tank and the lieutenants using sniper and range, the final boss should be pretty easy if you take your time and have decent add clearance...
ps3ud0 :cool:
Yes, the tank itself is quite easy due to the Arc boost. Arc snipers rip it to pieces, 4 rounds on each leg and its done for. The final boss isn't the easiest but he doesn't get any bonuses here so you just need to be careful. I just hid in the corner, I wasn't about to do it a third time if I failed.
I got an exotic helmet as a reward. It's a voidwalker one called 'Skull of Dire Ahamkara'
Has increased grenade throw distance, more super energy from grenade kills and 'Tougher while using Nova Bomb. Improved energy drain'
Don't know what that last part means as it doesn't elaborate on how energy drain is improved.
We did that boss serveral times on the bounce last night as part of the tiger strike playlist
With two defender titans providing alternating shields to go hide in its very easy :p Martin had blessing of light (extra shields) while mine provided weapons of light ( + 33% damage boost). No problems :p
It's the tank that gets me. The blast radius on its rockets must be huge, I always think I'm safely tucked up behind the rock column and then boom i'm dead. The boss itself always seemed relatively easy, just time consuming.
If you snipe it from where the lieutenants were on the raised platform connected to the central tower then the tank has a good chance of hitting the tree. Even if it doesn't, from that distance the shell has nearly a 3 second travel time, giving you plenty of time to avoid it
Well i had two weeks off work. And I play 3-4 hours a day nowadays after work.
Have not played last weekend cause ...
Rave on :] nothing beats a good rave :)
Today i am putting haswell-e build together.
Anyhow i love grinding daily bounties :) and playing loads of pvp helps with rep grind.
Fastest way to grind rep in my opinion is patrol Missions :)
