Re Touch ID, apart from unlocking the phone and app purchase....what else implements it?
Apple Pay, and as of iOS 8 3rd party apps can use it.
I use 1password so its used for every single login.
Is anyone else's Camera LED recessed?
Not sure if it's fell in or supposed to be like it. Quite sharp finish.
it looks intriguing, how difficult is it to set up for every login?
edit - I just tried it with amazon, went to the page in Safari, it's blank....? Does it not auto fetches info from the app?
Noticed that as well with mine. Recessed and thought it could have been pushed in.
Mine came out of the box like that so I assume it's normal.
Im pretty sure one password just stores your passwords etc.? Doesn't actually paste details in. Don't think any app can do that.
iOS 8 allows 3rd party apps to integrate directly with Safari meaning auto-login should be possible soon.
Edit: Both 1Password and Lastpass support this feature right now.
With TouchID tooOh wow, did not know that. May have to give it a go then.
Was it addressed to you by name?
