Sniper Elite V3 Benchmark
[email protected] - Sli 980's 1241/1753
Win 10 Dr 344.16
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-02 at 17:38:00
Version 1.11 Build Version: 2014.09.30.004
Average FPS: 108.5
Minimum FPS: 5.0
Maximum FPS: 777.5
Number Of Frames: 8247
Average Frame: 9.218ms
Minimum Frame: 1.286ms
Maximum Frame: 200.000ms
Machine Name: MONTY
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16327MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX 980
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Kaap my first round of stock 290X results are in.
[email protected]
1x290X@1000/1250
14.9 WHQL
1080P - Mantle
Sniper Elite 3 Benchmark Report (Mantle)
Created: 2014-10-02 at 16:29:22
Version 1.11 Build Version: 2014.10.02.001
Average FPS: 59.0
Minimum FPS: 22.7
Maximum FPS: 74.4
Number Of Frames: 4503
Average Frame: 16.938ms
Minimum Frame: 13.432ms
Maximum Frame: 44.037ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
CPU: Intel(R) Core(TM) i7-3970X CPU @ 3.50GHz
Number of Cores: 12
GPU Name: AMD Radeon R9 200 Series
Feature Level: Mantle
Dedicated VRAM: 4096MB
Anti-aliasing: HIGH
Supersampling: OFF
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1080P - DX
Created: 2014-10-02 at 16:35:42
Average FPS: 56.0
Minimum FPS: 21.0
Maximum FPS: 71.6
Number Of Frames: 4274
Average Frame: 17.852ms
Minimum Frame: 13.966ms
Maximum Frame: 47.618ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1440P - Mantle
Created: 2014-10-02 at 17:11:56
Average FPS: 36.1
Minimum FPS: 11.1
Maximum FPS: 46.3
Number Of Frames: 2766
Average Frame: 27.674ms
Minimum Frame: 21.613ms
Maximum Frame: 89.870ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Resolution Width: 2560
Resolution Height: 1440
Anti-aliasing: HIGH
Supersampling: OFF
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1440P - DX
Created: 2014-10-02 at 17:00:23
Average FPS: 34.7
Minimum FPS: 11.5
Maximum FPS: 120.7
Number Of Frames: 2664
Average Frame: 28.796ms
Minimum Frame: 8.286ms
Maximum Frame: 86.603ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
4K - Mantle
Created: 2014-10-02 at 16:53:56
Average FPS: 17.3
Minimum FPS: 5.7
Maximum FPS: 21.3
Number Of Frames: 1339
Average Frame: 57.711ms
Minimum Frame: 47.012ms
Maximum Frame: 176.372ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: OFF
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
4K - DX
Created: 2014-10-02 at 17:03:06
Average FPS: 16.6
Minimum FPS: 6.1
Maximum FPS: 41.0
Number Of Frames: 1287
Average Frame: 60.247ms
Minimum Frame: 24.386ms
Maximum Frame: 164.733ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Crossfire support is due in a up and coming patch.
Its crap from what im seeing so far,
Average FPS: 52.3
Minimum FPS: 17.6
Maximum FPS: 73.1
ed: as seen above no crossfire support so im in single gpu mode apparently.
Supersampling is turned on in game but according to the txt files its not turned on. Roughly 40fps difference in favour of d3d11.
Matt there is a problem with the Super Sampling on the results screen for Mantle so I can not use them. Can you use your contacts to get this fixed as I am sure Super Sampling is in use but not indicated.
I will report it Kaap. It's definitely enabled though as my fps shoots up with it off.
be careful there is a massive virus in the latest Sniper Elite 3 download, AVG has just detected it, i had to delete quite a few files and i dont think it's safe to redownload them... i can only play Sniper Elite 2
it's called :- Luhe.Fila.a
[email protected] - 980 1241/1753
Win 10 Dr 344.16
1080
Created: 2014-10-02 at 18:17:08
Average FPS: 58.8
Minimum FPS: 9.9
Maximum FPS: 564.1
Number Of Frames: 4499
Average Frame: 17.002ms
Minimum Frame: 1.773ms
Maximum Frame: 100.816ms
Machine Name: MONTY
Monitors: 1
System RAM: 16327MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1440
Created: 2014-10-02 at 19:02:02
Average FPS: 34.8
Minimum FPS: 10.0
Maximum FPS: 391.5
Number Of Frames: 2668
Average Frame: 28.713ms
Minimum Frame: 2.554ms
Maximum Frame: 99.541ms
Machine Name: MONTY
Monitors: 1
System RAM: 16327MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
3970X
290X Crossfire @1000/1250
14.9 WHQL
1080P
Created: 2014-10-02 at 18:12:42
Average FPS: 108.6
Minimum FPS: 15.3
Maximum FPS: 1118.2
Number Of Frames: 8196
Average Frame: 9.244ms
Minimum Frame: 0.894ms
Maximum Frame: 65.392ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Rebellion did a great job with this benchmark, It's so consistent. All my scores are within a fps of each other.
Win 10 Dr 344.16
reinstalled drivers
Created: 2014-10-02 at 19:33:33
Average FPS: 110.8
Minimum FPS: 7.3
Maximum FPS: 798.2
Number Of Frames: 8433
Average Frame: 9.024ms
Minimum Frame: 1.253ms
Maximum Frame: 136.528ms
Machine Name: MONTY
Monitors: 1
System RAM: 16327MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
it's migrated elsewhere......i've deleted the effected files and i'm waiting to see if AVG has stopped it in the other area, forget what that Idiot from Rebellion has said, this virus is a bitch
i will not reload the missing Sniper Elite 3 files for a few weeks
It's AVG being **** mate.
https://www.virustotal.com/en/file/...08e752b87a731759b8e737ba/analysis/1412279273/
That virus is an old one, if it was infected every bodies virus scanner would be going mental.
yes but you cant play SE3 ................AVG wont let you finish the download, it stops it every time as soon as it sees the virus, i have to wait until Rebellion remove it from the file.....you can not play any game on Steam if it is downloading something, it always makes you wait...... my version that is !!!
[email protected]
14.9 WHQL
1x290X@1000/1250
1080P
Created: 2014-10-03 at 07:28:39
Average FPS: 56.1
Minimum FPS: 21.3
Maximum FPS: 74.5
Number Of Frames: 4250
Average Frame: 17.831ms
Minimum Frame: 13.426ms
Maximum Frame: 46.995ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
2x290X@1000/1250
1440P
Created: 2014-10-03 at 07:56:57
Average FPS: 67.9
Minimum FPS: 9.5
Maximum FPS: 895.9
Number Of Frames: 5141
Average Frame: 14.720ms
Minimum Frame: 1.116ms
Maximum Frame: 105.419ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
2x290X@1000/1250
4K
Created: 2014-10-03 at 07:51:53
Average FPS: 32.5
Minimum FPS: 5.4
Maximum FPS: 856.8
Number Of Frames: 2462
Average Frame: 30.783ms
Minimum Frame: 1.167ms
Maximum Frame: 185.781ms
Machine Name: MATT
Monitors: 1
System RAM: 16316MB
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
96% scaling at 4K
95% scaling at 1440P
94% scaling at 1080P
Crossfire doing its thing.
Have to say as an AMD fan and a Mantle Fan, im disappointed in the gains in Sniper elite 3 with Mantle, on my rig i was getting 52fps at the settings here under DX11, and Mantle pushed it to 55fps.. 3fps increase? :( was hoping it would hit an average of atleast 60fps.
its liike a 5% perf increase on average fps i guess, which is nothing to be sniffed at, but its kinda disappointing still
avg just delete/uninstall it.
also in the benchmarks matt posted recently it showed mantle and amd cards came out on top yet this shows nvidia cards are actually better. :p
Single 980 @1516/7800
4790k @4.4
344.16 Drivers
DX11
Created: 2014-10-03 at 11:32:20
Average FPS: 39.1
Minimum FPS: 11.4
Maximum FPS: 271.1
Number Of Frames: 2986
Average Frame: 25.594ms
Minimum Frame: 3.688ms
Maximum Frame: 87.800ms
Machine Name: MARK-PC
Monitors: 2
System RAM: 8134MB
CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
