- 24 Apr 2011
Do you run with vsync or frame cap though? As this will lower the temperature. I run with 300fps on csgo and never cap my frame rate in any game. This makes my cards work even more and give off more heat. If I was to cap my frame rate to say 120fps my temps would be even lower.
I'm using same settings before and after the update. Always have it capped to 200fps (using fps_max 200)
