- 29 Aug 2010
- Cornwall
Might as well spend that little bit extra then for that little bit of quality, I know I've got a small PSU bit its a decent bit of kit, might look into upgrading the processor/Mobo in the new year with a mind to crossfire in the future so I'll be upgrading the PSU then so this little upgrade itself isn't fully long-term (...if that makes sense)
One thing to keep in mind with the Tri-X is that the cooler take up a little bit more than 2 slots (2.5 or something). Worth considering if/when you crossfire (or buy a motherboard to crossfire with).
I should also point out I've not had an XFX card (for a while) so I've no first hand experience with the quality, it's just the impression I get. I'm pretty sure most will tell you the Tri-X is a good card though. It's what I'd get.
