So I got my card today, middle of the road clocker it seems from first glance. (Always the way!). -1541 max STABLE and 0 issues I saw in heavean (69% ASIC, pretty jealous of you guys and your easy 1600+!).
Which card did you end up getting?
Also have a FT02 ( heat pipe orientation etc etc) and your temps look good.
Went for the MSI card in the end, heatpipe orientation seemed to be the best out of the big 3. Cooler fibs also go the right way as well unlike the gigabyte one.
(considering how cool it runs though it would be nice to know if the GB one remains in acceptable levels given its compatibility issues..)
Two downsides to it though-
No backplate/flimsy cooler
Lack of display ports.
On the plus side it fits without having to worry!
What kind of score is everyone getting in Firestrike on a single 970?
Seems my singe 970 is outperforming the 690.
970- http://www.3dmark.com/fs/2880405
690- http://www.3dmark.com/fs/2692858
Think I've found a way to flash these cards!!
Testing atm...will report back!
IT WORKS!!!!!
JUST FLASHED MY STANDARD PALIT GTX 970 WITH THE PALIT JET STREAM BIOS AND IT WORKS!!!!!!!
GIVE ME SOME TIME AND I'LL UPLOAD EVERYTHING WITH A GUIDE SHORTLY!!
