- 30 Nov 2011
Hi guys, finally got my Asus rog swift setup. Still tweaking the settings and getting used to everything but so far i'm impressed. I don't know how you guys can use such low brightness/contrast though. I have mine on 80 brightness 75 contrast in normal colour mode.
One thing that is annoying me, I can't change the refresh rate by pressing the button on the right of the monitor. All that does it show what refresh rate the monitor is set to. The only way i can change it is to right click on desktop>screen resolution>advanced and set it through the monitor tab.
I was under the impression I should be able to cycle through the modes by simply pressing the button on the back of the monitor. Anyone know how to cure this?
These are the settings I found favourite, a lot of good feedback in the "monitors" thread for the swift - brightness is really just a function of how bright your room is, I tend to play at night with low ambient
I tend to find on these newer TN's that setting the monitor brightness higher and then backing it off in the NVCP leads to better blacks without losing the brighter colours - out of the box the blacks end up quite grey I found without these changes
I've spent ages fiddling trying to get settings I like (and having found this easily on the Samsung 4K, I knew it must be possible on this one too and I wasn't letting "but TN" get in the way)
On the monitor: Brightness 40 (30 at night), Contrast 50, Colour Temp User (R95, G100, B100)
Nvidia Control Panel: Display: Adjust desktop Colour Settings: Use Nvidia Settings
Brightness: 40%
Contrast: 45%
Gamma: 0.8
those are the settings that work best for me, your mileage may vary
