 - 25 Nov 2011
 - The KOP
I wonder how stupid this guy is feeling after the recent results.
Come on Lt we need a few Mantle ones out of you too.![]()
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-05 at 03:57:27
Version 1.11 Build Version: 2014.09.30.004
Average FPS: 108.5
Minimum FPS: 20.2
Maximum FPS: 666.6
Number Of Frames: 8248
Average Frame: 9.214ms
Minimum Frame: 1.500ms
Maximum Frame: 49.495ms
Machine Name: MINE
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16351MB
CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Number of Cores: 8
GPU Name: AMD Radeon R9 200 Series
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Nice score on single 290x matt i nead a 290x@1360-1370core to tie yours when in dx vs yours in mantle.![]()
Yes i am using Pt1 bios on my 3 290x gonna try 1625 mem. But with that mem i most likly gonna get higher core oc![]()
Nope is not memory correction for me get 2.5fps lower avg in dx with 1625mem vs 1725. Think the diff is you have better ram timmings and raw cpu speed.
my cpu is 4930k@4750 ram 2333 at cl10 t2 (32gig)
Created: 2014-10-05 at 17:19:49
Average FPS: 133.9
Minimum FPS: 15.5
Maximum FPS: 881.0
Number Of Frames: 10171
Average Frame: 7.469ms
Minimum Frame: 1.135ms
Maximum Frame: 64.721ms
Machine Name: PULSE88
Monitors: 1
System RAM: 32707MB
CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
Number of Cores: 12
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Could be mate, I spent ages tweaking my memory timings. Thanks for trying though.
