Yes, so far it's only an issue on Battlefield 4. Other Mantle games use much less vram at 1080P. Any further problems just shout.![]()
a fix from dice expected soonish?
Which cards are you using russell?
There is not a profile for Fifa 15 as it's not very demanding. However you should be able to create one yourself if desired using 1x1 optimize. I've tested this myself and it works without artifacts.
Are your gpu's overclocked at all? Are you using MSI afterburner unofficial overclocking mode?
Hi Matt, thanks for the support! AMD should be chuffed to bit with the support you give!
I have 2x Gigabyte 270x's which are Overclocked to 1130 mhz care and 1420mhz memory. My cards are locked voltage so can't go much higher.However, I have ran these cards at these clocks for at least 5 months now and run F@H a lot and never had a crash or anything like that.
I noticed FIFA 15 uses like 40% at max settings, and the second GPU turns off as it isn't required, I'll try creating the profile, the graphical glitches start randomly, but most of the time if I go away and leave the game paused for a little while.
In regards the MSI afterburner, I have had the very occasional flickering going on when the cards are idle, I remember having this since 14.4 (I could be wrong) but with two monitors I notice it more, but again it only happens when the cards are idle and drop to (Or below). Could you maybe point out how to manually set the idle 2D clocks on MSI afterburner, as I can't find it anywhere, only the 3D ones?![]()
Thanks russell for the kind words.
Please put your cards back to stock for this, as instability here could be causing those artifacts. Also where crossfire is concerned, if the cards aren't fully utilised (99% usage) then overclocking will not really add much more performance. Running stock to get the gpu usage higher will provide better results, at least in fifa 15.
Copy these settings and away you go.
If you have performance to spare and want to up the image quality, use supersampling. Ensure you have either x2 or x4 AA selected in the Fifa options prior to starting the game. Then copy these CCC settings exactly.
Doesn't it look nice?![]()
Try bumping cpu voltage first, (at least 2-3 notches) then work on the others if it still occurs. I know what you're saying, but this would be my recommended first port of call.
Do these 14.9.1 resolve red screen crashing? My rigs been stable until these 14.9's. Been trying to play shadow of mordor on my 290 but I keep getting a lock up to red screen!
Red screen is caused by cpu and or memory timings/voltage instability. Try bumping those voltages at least two notches and see if it still occurs. I've dealt with many red screens and they've all come down to this.
I updated to 14.9.1 and upped my vcore and mem volts a little. Just played Mordor for an hour. Seems fine now Matt, thank you!
Russell a few screenshots with Supersampling enabled at 4k. I'd definitely recommend enabling it (if performance allows at your resolution) and using the crossfire profile i provided above.
AMDMatt
Hi matt can you tell me the best fix for shadow of mordor using a 7990, and do you know when amd will be releasing a profile
i am using the tombraider profile, it just seems to stutter now and again any ideas?
thanks
a lot
Maka
Hi Matt, again thanks for your input.
A screenshot of my afterburner settings:
However, I have noticed with my Fifa 15 it now crashes on the startup screen after trying to connect to EA.I have removed the settings and tried again but its a no go.. Strange I'll reboot soon to see if that fixes it.
I will try with the 2D + 3D settings, are the 2D settings in the same place and the 3D ones? I'm new to afterburner, but wish to get to know it more kinda thing.![]()
Hey Guys, my mate who runs a pair of 7950s and an 8350 (that I built) has just text me with an issue. He said he was on 14.9 and auto update started downloading the latest AMD drivers (which he assumed were the same as he had), he let them download and install and now he has a black screen. To save me going there and fixing it, any easy fix I can tell him to do?
From his text message.
A window popped up saying AMD software update. Think I miss clicked something, as I had never seen that update before but then it went onto driver installation. restarted the PC and it said "Driver update available"
Just black screening when trying to game was his first message.
Told him to do that. He is at work till 10pm (hahahahahahahaha) and will do it after. Fingers crossed that will sort it.
Matt just a thought, if you guys are working on resolution scaling for the next CCC it's the sort of thing that might tempt a lot people to go Xfire and buy another 290....especially when price drops filter through....
just a thought...
Keep us posted about bf4 too big man. thanks!!
