What's wrong with a pair of scissors?![]()
Yeah 3.5hrs screen on time over 4 days? You may as well have bought a brick with a sim slot![]()
17 hrsI thought this had near 2 day battery life?
Any of you lot experienced "sd card was unexpectedly removed" repeatly?
My phone keeps popping up with this message then remounts the sd card repeatly.
Not sure if it's the Sandisk 32gd micro sd card but it was working fine in transfering files back and forth to other devices before I popped it into the phone.
I got a Lexar 64gb micro sd card on the way tomorrow so will swap them round and see if the problem persists.
Yeah I've been getting this. I only seemed to have noticed it since I put in a 64gb Samsung card. I didn't notice it with the 32gb Sandisk before it. I might try to re-insert it to see if that might help, as it was a bit tricky to get in.
I'd have thought it depends what you want out of the OS, as they are all good phones! This phone is smaller than the iPhone, so I guess size is another factor. This is also considerable cheaper than the iPhone.Anyone come from an iPhone 5s or better yet a standard 6 to this? What are your thoughts. I'm torn between an iPhone 6, this or a Lumia 830....
The Z3 loves to go swimming tooMight need to get one of these sooner than expected, I was hoping to wait until Christmas but my iPhone 4 just decided it was waterproof and went diving... now it keeps randomly calling people using voice control, so I have switched it off to give it a chance to dry completely and we'll see![]()
