- 22 Jul 2012
- London
2600K @4.8
290 @1275/1625
1080p
14.9
290 @1275/1625
1080p
14.9
you need to host them on an external site, then use the image icon above in the test box and add the link of the image.
Any tutorials please
Sure. Sorry, I haven't been about much today and I often miss posts in here tbh.
Managed to eke out a tad more too![]()
Is it watercooled or on air?
They're on water.
I guess your cpu @4.6 is roughly the same or very close to mine @5.0, but I'd still have thought the GPU clock difference would add up to more than 0.4fps though
Have you got any room for more on the core?
Can't get my vram higher than 1625 sadly, though I've only bothered to try 1650 really. Not sure it makes any real difference tbh.
I see. Don't think I have very much left on the core. If only the Vapor-x was not voltage limited it would do more as the temps are fine even on air. Might be able to overclock my 3770k a bit more though although we could be eeking more performance out of our 290's for a while if I did that.![]()
1285 is my limit unless I fart about with flashing bios' etc. Not my style though, so that's me done here![]()
For a single card on this 4.6 is plenty on the CPU.![]()
Well done, chaps. Updated.
I'm afraid my card is all eked out...
