- 8 Jan 2009
No worries. I think I will get the fine one.
Bummer, wanted inexpensive model so I would not worry much if I mess it up painting it, and just realised that Panther I ordered (Tamiya 35065) is very old and inaccurate kit...
I know how you feel. I never worked on ships before so starting with this since it's got few parts and should be easy enough but the parts are insanely small.
Really, I should had got a cheap set and was looking on eBay but just couldn't find anything, so I just went ahead anyway, I done 40k before so used to modelling so I won't make such a bad job but I try my best.
So far am doing okay, I made a few mistakes but it's better I learn now before I start working on my bigger ships like Haruna and Kaga and the like.
I have a build log here: http://forum.model-space.co.uk/default.aspx?g=posts&t=13424
I get my desk light tomorrow so that will really help with building this and the others.
