Dunno, didnt think to check that, normally its fine.
I noticed that the GPU usage isnt pinned at 100%. Might have some throttling going on...
Nice one
Maybe Win10 is helping things along perhaps?
Don't worry about me, she cannae take any more!
Your graphics score looks about right
You are running 25mhz faster than the 295X2 on the core but 275mhz slower on the memory. I suspect that memory speed plays a part on this bench as LtMatt has better memory on 2 of his cards and scores a lot more on graphics than I do.
Depending what you are using it for a 295X2 can have an advantage over 2 separate cards as the two GPUs talk to each other before going through a single x16 PCI-E 3.0 slot.
Temps are fine so no throttling there and I've turned my O/C down from my 1150/1400 max as I get minor glitching in 3dmark. What else could cause throttling?
Not really got much more room for O/Cing memory but not tired on these drivers, even though MSI has decent memory it doesnt seem to O/C as much as one would think.
I will try upping the memory later to 1450 see what happens.
None of my systems have ever been any good at benching, I see scores on here with the same hardware and think HOW!!!
Thanks. It might be the memory clocked to 1700 more than Windows 10. I don't think mine will take much more before she blows either.![]()
That's a good point. I forgot about your mem OC... Mine do 1625 tops, and I had to run 1600 on this or they'd blackscreen when returning to 2d clocks (at least I think that's what happens) more often than not at 1625
Hynix ain't always the nuts![]()
The dreaded black screen.Mine is voltage limited on the core. It's a pity there was not a bios that removed the restriction. Don't think I will try the Tri-x bios with the differences in pcb etc. Might end up with one dead card.
What added voltage are you running your card to get so high on the core? Are you adding +200 to stock voltage or +300?
I'm running +200mv via Trixx.
Half tempted to flash a bios etc to possibly go higher, but I like to er, keep it realI'm a (part time) gamer, not a bencher. I just do it to see how my stuff stacks up against others really.
Is there no bios you can use to get around the voltage lock? You do have a dual bios switch on there, don't you? If so, there's no risk of bricking your card.
I've bettered my score by a few measly points, but think I've reached my limit now. Still for now I have the second best score in the world.
Cant wait to try my 290 later on![]()
At 1300+/1700+ it will beat mine for sure.Watercooling, not voltage limited and living in Norway all helps for sure.
Yes yes, and its somewhat cold here right now. Should be interesting![]()
