- 1 May 2013
- M28
I am still running trusty 14.4's, do the latest 14.9.1's have the temp increase that the post 14.4's suffered from?
You'd think they would include a suitable cable lol. From reading posts by others it seems the supplied cable works fine for Nvidia users.This could be the problem then, often the supplied cables aren't up to standard. It was the same with the 4K monitor i got, i had to buy a certified cable as well. Best bet would be to look at the cable and check if it's DP 1.2 certified. If you're still unsure, contact the monitor manufacturer to check.
New 14.9 drivers are causing me red screens and total lock-ups on BF4.
What is the latest 100% stable driver?
Hey Matt, are you chaps working n Crossfire support for The Evil Within?
If I create a custom profile and use AFR I get a performance boost, but the game has lots of flickering, texture tearing, and artifacts.
A single card can't even keep a constant 30fps at the moment.
I believe ID Tech engine doesn't work with crossfire?
** Competitor suggestion removed **
Which AMD cards are you having issue with GM?
Just got my MSI R9 290 gaming today, wondering what drivers are best for the 290 models?
I need to asks question that amdmatt or anyone with knowledge of drivers could answer, why is it on the last 2 drivers amd have released (14.9-14.9.1) that they don't install properly as when the install is finished I get the yellow question mark instead of the green tick.
I have done the uninstall the same way I always do using uninstall manager first then ddu but it still shows the big yellow (?) why is this?
if it helps, i had the same issue.
i ran ddu to remove everything and the a run of ccleaner seemed to fix it.
ran installer and it seemed to work fine.
So it sounds like ddu is not removing everything then.
