- 22 Mar 2009
Billion 8800NL are the best chipset VDSL2 and I got no problem with it so far.
That's not totally fair. The RT-AC68U I'm using has been brilliant, it's just the DSL version that's a big steaming bag of ****.
Might be a bit early to start dancing yet. Got a week of monitoring before those stats will set in stone. I would reboot as well as when it says line attenuation 0... this is not correct.
Your dbm seems a little high as well have you enabled UPBO.
lol, mines had a little time to settle but making any adjustments in the first few days saw the lines stats vary wildly.
Im not sure I will keep it on performance... or disable the stability adjustment. one of the two is having a higher CRC error rate. Not huge but probably double the amount it was last week.
ping is great also![]()
oh well we can put it all down to we have great speedslol
i got told off a BT open reach guy that you can switch off and on your router as ment times as you like as long as you dont do it between 12 midnight and 3am as thats the time the DSLM does it line checkingthere for as long as you do it before then or after then it will not trip the DSLM into thinking your line is faulty and reducing your speed due to powering off and on or changing router settings ect....
Wrong! DLM is in action 24/7/365 at all times. Be careful if you turn off on all times on the VDSL2 modem, or tweak adjustments can leads u to DLM hit! It's happen to me once and I seem other peoples doing this end up DLM hit! Just be caution.
