** New Product Anidees AI-07 ATX Case **
7 Feb 2011
Stoke on Toast
The AI-7 is a ATX chassis which focused on cooling performance and maximising configuration options, this chassis maintains Anidees’ pedigree of compact size and quality build that would look great in any spaces.The dual chamber design divides hot running components, one chamber deliver cooler air to MB, CPU, GPU, another one for HDD and PSU.The chassis comes with four 120mm led fans on the front and also can be upgraded with several additional fans if needed. Featuring several options for placing water cooling, providing excellent cooling solutions, the flexibility of this case really gives the users the possibility to create their great system build.
Dual chamber desi gn for best cooling
- Direct air flow cooling all components
- Supports max 8 case fans
- Quiet operation with 200 mm fan (optional)
- Supports 3 x 240 and 1 x 120 mm water cooling
Spacious but not big that you thought
- Supports ATX, m- ATX and mini - ITX
- Supports 1 x 5. 25" , 4 x 3. 5" or 5 x 2. 5" devices ( 4 x 2. 5" convert from 3. 5" cage)
- High end components support - Max GPU Leng t h 348mm, CPU Height 174mm, PSU Length 200mm
- Cable routing behind MB tray up t o 95mm
- Compact size with 41.5L
Excellent structural design
- Dust filter on the front, top, bttom and side panel
- 3.5" Tool Free HDD Trays
Specifications:-
- Dimension ( D/ W/ H ) 380 x 288 x 380 mm
- Weight 6.35kg
- Material Steel, Plastic
- MB Support ATX, M-ATX Mini-ITX
- I/O Panel 2 X USB 3.0 2 x USB 2.0 1 x Headphone 1 x Microphone
- Expansion Slots 7
- Power Supply Support ATX (upto 200mm deep)
- Cable rounting behind MB tray 95 mm
Cooling System (air)
- Top 2 x 140mm/120mm optional
- Front 4 x 120mm Included
- Rear 1 x 120mm Included
Cooling System (Water)
- Top 1 x 240mm Radiator
- Front 2 X 240mm Radiator
- Rear 1 X 120mm Radiator
Anidees AI-07B ATX-Cube - Black @ £67.99 inc VAT
Only £67.99 inc VAT.
ORDER NOW
Anidees AI-07BW ATX-Cube - Black Window @ £76.99 inc VAT
Only £76.99 inc VAT.
ORDER NOW
Anidees AI-07W ATX-Cube - White @ £67.99 inc VAT
ORDER NOW
Anidees AI-07WW ATX-Cube - White Window @ £76.99 inc VAT
ORDER NOW
The mobo tray gap on the right is huge, could be bad if looked at the wrong angle and see wires, though cable management shouldn't be a problem, and 4 front fan, componants shouldn't be short of cool air.
I think its quite an attractive little case.
Should be in silver as well IMO. Nice looking case (without the LED fans). Could be a project build.
Now there's a nice alternative to Corsair's 540 and it has dust filters as well as being a fair chunk of cash cheaper. Good watercooling potential tt.
Glad you all like it had a chance to look one over yesterday seems like there are a few options for water cooling although I think they are a tad optimistic on the 2 240's in the front I think they mean I think 2 AIO rads will fit I'm not sure if my SR1 240's will fit side by side. :)
All in all a good looking case at a good price with lots of options.
The Phobya Quad Radiator should fit in the front?
the Cooltek one looks better i think finners o and post some picks m8 :)
will do when I get it, missed the delivery today so will pick it up tomorrow. Think I made a bit of a balls up though, Not sure my rad will fit in the bottom with an ATX board.
Time will tell i suppose!
