***The Vapers Lounge***
Status
Not open for further replies.
Unfortunately I can tell within 2 puffs if a liquid has any PG in it, even just flavouring. "Max VG" for example.
Virgin Vape stuff definitely 100% PG free :)
Have ordered 4 x bottles just today :D
FYI, how does PG allergy feel like?
The alcohol is giving a decent throat hit, but i need to vape like 5ml at least to see whats going on.
Should i be steeping this or what? Is absolute virgin vapor line much thicker as it has no alcohol?
Edit: Apparently they are both thin.
For me (it is different for other people) my asthma kicks in.
Usual rattles / wheezing as if I've been in a hot, dry room for an hour.
I haven't found steeping to make any difference with it.
I feel as i have just had a shot of coffee flavored vodka,
Ok so my plan is.
Place open bottles in water at 80c and attempt to evaporate as much alcohol as i can.
I guess i will post back tomorrow or something.
just ordered the Vamo V6 20W, for a bit of a change, anyone had any experience of it?
best clearomizer for it etc? to start I will be using the iClear 302 2.1 ohm
Been using 10 motives from Tesco for 18 months now. Getting fed up with £7.99 for a pack of 5 and poor quality refills recently.
Can anyone recommend a decent e-cig falling into the following criteria:
- not huge
- doesn't have to look like a real cig but I don't want something "bong-like" lol
- excellent battery life
- decent voltage (presumably variable is best)
Cheers
Well gents I've gone cold turkey - no vaping for two days and am starting to climb the walls!
Stopped because the HS menthol sensation is playing hell with my tongue and throat! I'm not sure whether its the fault of the e-liquid, I've read you need to drink plenty with vaping but unfortunately that's never been me.
If I could change liquid to avoid a dry tongue and a dry irritated throat which I constantly feel the need to try and clear I'd be happy!
- not huge
Cheers
I was in the exact same position a few weeks back, and I was recommded the iTaste MVP,
yes its a mod and its a bit bigger, but the difference is amazing, I got this one
http://myepack.co.uk/mods/itaste-mvp-v2-0-metal-grain.html
but if you want something smaller, then the VIP range look OK, seen a few guys using them on holiday,
- not huge
Cheers
That's why I started building my own. Was buying 10 motives as well and the filters became suddenly of a very poor quality. It went from a cartridge a day to twenty minutes and they tasted like they were done. Needless to say I sacked that off and bought a kayfun. Its rebuildable but you won't be buying coils just juice. Get a kayfun light and a vision spinner 2 or an MVP 2.
The reason I say buy better stuff now is most people end up buying it anyways and it saves buying a load of stuff before you end up buying them in the end. Don't be put off as the experience is a million times better
- not huge
Cheers
Eleaf iStick or if your feeling flush Vapor Shark rDNA with a Silo tank or (mini) Nautius.
Status
